Model
2017 (66 plate) Volkswagen Transporter Kombi T Highline Short Wheel base 6sp Manual,
Titanium Black/Titanium black-Anthracite/Black interior
Additional options
Oryx white mother of pearl effect
Captains chairs with arm rests
Additional Dust seals on front Doors
Composition Media Radio with 6.33 Touch Screen
Power Folding Wind Mirrors power adjust and heated with orange vinyl wrap
Headlamp washer system with heated front washer nozzle
Heated front seats
Mud Flaps front and rear
LED Headlamps with LED Daytime running lights
Power latching side door and rear tail gate
Second maintenance free battery with cut off relay
Side Curtain Airbags for driver and front passenger
Removable and lockable towbar with trailer stabilization
USB interface for iPhone
Heated front windscreen and wingmirrors
Insulated privacy glass.
Sliding OEM rear windows (Have never leaked unlike some report)
Reverse Parking sensors
Additional Interior
Fully sound deadened panels in rear of van, including floor and roof with Silent Coat 3mm
Fully Insulated using DODO Closed cell foil backed foam, inc floor and Roof
Voids packed with recycled plastic bottle insulation which does not retain moisture
Fully Lined with Insulating underlay, and faux suede/Alcantara custom in blue orange and light grey.
Black out blinds on rear windows.
12mm ply on floor with 15mm oak floor
Caravelle Sliding rail System from a T5 with Caravelle Bed system, inc. aftermarket FLEX board system. Fully Braced with OEM Braces under floor.
Wireless charging pockets to the rear of the van
COB LED Lighting for cool temperature lighting, 3 Strip lights, One connected to the internal "Coming home" lighting function of the van but also controllable remotely to the leisure battery (isolatable via switch). 2 COB LED lights controlled by touch dimmer switches connected to leisure battery and independently isolatable via switch.
1800 individual fibres on 2 Fibre optic roof lighting units powered by the leisure battery and remote operated x 2, or sound operated. Flashing/fade function. Galaxy layout. Can be removed
Caravelle higher side step at side door and tailgate
Swivel base plates on both front captain seats (drivers seat is offset swivel)
Handbrake has been lowered to allow swivel plate to be fitted without the raising bars supplied by manufacturer.
Additional External
Tailgate spoiler in orange wrap ( unfortunately damaged due to a delivery lorry leaving no details. Approx. £100 to refit new)
5fourty VanSlam Adjustable Coil overs, Two new rear Dampeners and bushes (old bushes were shot)
Standard Alloys running All Terrain BF Goodrich KO2 Tires.
Rain Rail roof prepared roof bars (Cost £350)
Additional Engine
KnN Panel Air Filter
Common Fault Repairs
EGR replaced under warranty August 2020
NOX Sensor Replaced August 2020
Passenger Wing mirror replaced due to not electric folding
Sliding Door Catch Replaced as damaged from new
Tailgate soft close mechanism replaced due to failure.
New main Battery as of June 2020 (larger capacity stop start)
Servicing
Fully serviced at main dealer
Major service at 80,000 miles at main dealer
1 year MOT'd Sat 23rd October with retained MOT date of November 13th (annually)
Available
Thule Cross Bars (will come with the vehicle if sold at a good price)
2 Road Tires with good Tred
Standard Suspension dampers and springs
Front and rear 4K safety camera (£300)
Body Work
Paint is in very good condition generally,
There is the usual side sliding door stone chips which needs small amount of touch up.
Minor light scratching but generally well looked after paint with usual age related stone chips
Brakes
All breaks are in good nick, recently cleaned and working well
Tires
Tires are off road BF Goodrich KO2 with loads left on them.
There are two road tires that can come with the van if sold at the right price
The spare is unused, wheel is a bit rusty from being under the van but to be expected.
Mileage
Just turned 80,000 and will be used minimum 3 days a week for commuting so expect to go up.
Other Repairs
Windscreen replaced under insurance policy due to stone chip repair cracking further (Replaced Winter 2019)
Bad points
Minor rubbing on passenger door card plastic (oops)
Plastic Belly pan damaged but not causing issue (£300 to replace), joys of snow days ;D
Rear window additional tint could do with being replaced/renewed
Minor mark on rear bumper
Paint protection film on rear bumper needs renewed
Minor scuff on one alloy I know of approx. 10mm
Additional Information
MPG, Keep it below 1800 RPM and you are up in the 40's easily,
Drive at 70 and approx. 36MPG
With Large roof tent 36MPG
Addition of BF Goodrich tires 34-36MPG dependant on road surface
Always been run on premium diesel apart from the odd occasion there was none at a pump
I have a new Alternator belt to fit however yet to do. It will either be fitted or come with the van.
Oh and removable tow bar....
Additional options
Heated front seats
Additional Interior
Additional External
Additional Engine
Servicing
Available
Body Work
Brakes
Tires
Mileage
Other Repairs
Bad points
