Hello.
Adding this to the VCDS-VagCom / Carista / OBDeleven section.
There doesn't seem much info on this code. Has anyone any experience/ intel?
ENGINE
05649 -
Freeze frame :
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Odometer reading: 67296 km
Engine rpm: 878.00 RPM
Normed load value: 28.2 %
Vehicle speed: 4.0 km/h
Coolant temperature: 63 °C
Intake air temperature: 9 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.724 V
__________
There doesn’t seem to be much information on this code with only the dodgy looking VWcodes.net returning anything, and it’s not very specific:
“Accumulated in electronic control units so O2 sensor signal bank 1 sensor 1, biased / stuck rich run rough, or might suddenly stall at any given speed direct one reduction catalyst deterioration sensor, circuit low. On the other hand ignition coil ‘f’ primary control, circuit low will delay your vw fault”
“05649 vw fault code may be caused by one or more of the following:
ENGINE
05649 -
Freeze frame :
Priority: 2
__________
- Manifold Absolute Pressure/Barometric Pressure Circuit High Input
- Fuel Temperature Sensor B Circuit Range/Performance
- Injection Pump Fuel Metering Control 'A' High (Cam/Rotor/Injector)
- Reverse Input Circuit
- O2 Sensor Heater Circuit Malfunction
- Injector Circuit Malfunction - Cylinders
- Injection lump Fuel Metering Control 'B' High (Cam/Rotor/Injector)
- Ignition/Distributor Engine Speed Input Circuit Malfunction”
