dmf failure
  1. CaptainZag
    Dual Mass Flywheel/Clutch/Thrust Bearing?
    Please could someone help/advise. I have uploaded a short video of my T6 starting from cold with the clutch in, then releasing clutch, then depressing and releasing the clutch a few time. You'll notice that when the clutch is depressed the engine is quiet-er and when I partially depress the...
  2. PullersSWK
    Is this DMF failure?
    Hi Guys. Opinions please….. Would you suggest this noise is DMF failure? It had one at VW approx 30k ago, DSG, doesn’t have any effect on function of the van as yet, bit strange if it’s going already! Would you replace this asap? Vans done 123k so worth doing a clutch pack to? Full...
  3. W
    Dual mass flywheel conversion
    Hi, I’ve got a 2015 camper, 5 speed manual, 102bhp, it’s done 135k and is calling for its second DMF, it’s looking like quite a spenny job, I wondered have any of you good people done away with the DMF and converted to a standard flywheel? If so how did it go? Looks to be a bit softer on the...
  4. D
    Can’t say this is a good flywheel surely?
  5. Wc04los
    Dmf+clutch kit recommendation
    Dmf on my transporter is chattering its tits off (2017 and 48k miles) which I think is p!Ss poor. Its a dsg if that has any influence on what to get. Any recommendations on what brand to get? Also having the timing belt and water pump done the same time, so same question applies regarding them...
  6. Stockwell Camper
    Engine Noise ID
    Van has been in for an MOT this morning, passed with no issues. They have however said that they can hear a knocking noise coming from the sump/gearbox area when the van is up on the ramp. Bit of background; T6 EU6 102 Bhp with 62k on the clock, had a new key programmed by VW 4 weeks ago during...
  7. J88arv
    HELP!!! DMF and clutch rattle after new one fitted??
    I’m now on my second new DMF and clutch yet still getting the odd rattle. is it my driving style as aposed to the DMF?? Any help welcome??
  8. RunDSG
    Diagnosing a DMF (dual mass flywheel) failure
    I’m still quite new to my T6. It’s my first Transporter. I’m hearing so much about failing DMFs and I’d like to know what to listen for. is it just the sort of rattling sound, as described here? (Not specific to the T6.) Or is there more to it?
  9. S
    How many with a T6 dsg have had a dmf flywheel failure before 50k, 100k and after 100k?
    Thought it would be interesting to see the numbers after viewing a t6 at the weekend! It clearly has a dmf issue at 122k, it also had a new one fitted at 53k by VW in 2017 under warranty was wondering the number of people who have had the same issue? VW just says its normal :rolleyes: I...
