Wheels stuck on
Just wanted to mention another method of removing wheels seized onto the hub when you haven’t got a mallet to hand.
Obviously first thing is some penetrating fluid and give it some time. Then loosen the bolts a few turns but leave them in.
Now, while the vehicle is on the deck, with the handbrake on, gently rock the van from side to side.
The motion and weight of the vehicle causes the seized part to become free and usually you will see slight movement of the wheel on the centre hub or even a crack sound when it finally releases.
Next, jack it up and see if it is free.
Repeat the process if necessary.
