Someone has nicked your back boxas above,
jack van up und put onto secure axle stands. . . .
spray WD40 penetrating oil on join between wheel and hub join.
use heavy duty rubber mallet and whack the inside edge of the alloy rim 3-5 times.
rotate wheel 90degress
repeat
use heavy duty rubber mallet and wacky the inside edge of the alloy rim 3-5 times.
repeat
keep going untill the rim breaks free from the corrosion.
hit wheel rim at red point, outwards in direction of blue arrow.
Adds about 50 bhp if you listen to it!Someone has nicked your back box
That’s the first thing I noticed in that pic!Someone has nicked your back box
Is this your van @Dellmassive ?as above,
repeat
repeat
