Wheel Bolts Question - Aftermarket Steels
These are the right bolts for the job. They are 19mm, designed for steels and the VW centre caps fit on them correctly (and the caps you've been supplied with look just the same). 37mm length worked for me to do the same job.
(I know I've told you this already in another thread Mark but it took me so long to find these that I hope by posting here I'll save others the same time and trouble)
Thought i'd post a last update on this for anyone's future reference.
Thanks for all of the suggestions and help - hugely appreciated.
After talking to Rogue, I was able to establish that they purchase the Ravage plus steel wheels from John Brown Wheels.
JBW have them made in China / Japan and import them. I spoke with the service team at JBW who confirmed that the correct bolts for the Ravage+ Steels are in fact radius seat 37mm. JBW have them specially made to fit both the wheel and the centre caps.
Have attached a photo of the wheel with shiny new KO2's on them, and one of the bolts that arrived this morning from JBW. The bolts ( also seen in wheel here ) feel like the correct fit immediately - perfect seat.
Dimension wise, the bolts are 19mm Hex, 37mm thread length, M14 x 1.5
If you buy a set of these wheels from Rogue, check the bolts carefully. I circled back to them after talking to JBW about the bolt spec - they said they were going to review as a team.
Last photo attached is with the new shoes on the van, & the centre caps supplied with the wheels fitting nicely.
JBW sell at set of 20 of the correct bolts for £29.95 in case anyone else hits this issue.
Cheers.....
