Guys I’ve had EXACTLY the same situation down here in Australia, after 3rd service the 2019 T6 Transporter (fitted out as very expensive Campervan) came back,with pink/red coloured Coolant. The Manual says engine damage will result unless you use G13 or G12++ both of which are purple.
I agree that any warranty issues will be sidestepped by VW and I’m not prepared to accept the word of a mechanic who has zero accountability if damage results. The Manual ( Edition 11.2017 Stand 31.08.2017 English 11.2017 Teile-Nr .:7E0012720BE) could not be clearer p. 240-241 “serious malfunctions or engine damage” could result.
The Coolant Expansion Tank is stamped G12 o o .
I’ve written to the supplier of the vehicle to seek clarification.
SUPPLEMENTARY QUESTION: Is it possible for the servicing dealership to have checked the spare tyre pressure without lowering the wheel? The valve is on the side of the wheel which is pressed up against the bodywork, but they claim they have checked the pressure. I know they didn’t lower the tyre / spare wheel at all, because I fitted a tell tale because I don’t trust them and it was not disturbed. So do VW have a nifty tool which enables them to check the spare wheel’s pressure without lowering the spare?
