Hi everyone, I am currently converting a T6 SWB into a camper. As I am planning on spending alot of time in the van ie travelling in europe when complete. I wanted to do without gas. I have webasto x100 stove whch runs on diesel. I wanted to see if anyone has had the experience of retrofitting a websasto evo coolant heater. As I would like the ability to use the heater to heat the cab and also run lines into the water heater tank which has a coil for cooliant to flow through and heat the water. It also has mains element for when on shore power.
I am just wondering if anyone could offer any help as to which coolant lines from the photo I've attached of the coolant lines going into the cab heat exchanger. Which is the direction the coolant goes ie which is in and which is out ? Is this the best place to join the webasto heater and coolant lines to the water tank?
I ve also tried to google any workshops or places that would be able to perhaps help in fitting the equipment. I am in manchester so anywhere local would be big help if anyone has any recommendations? I've tried PF Jones today several times but can't get through to them.
