Hello,
Has anyone had this issue? If so how was it rectified?
The drive side A post has recently started filling up with water and over flowing through the large wiring hole that the cables for the door run through and into the van.
The van is a 66 plate, I’ve had roof bars on since new and never had this issue until about 6 weeks ago.
I’ve checked and sealed the wiring loom on the A post, all good, windscreen is sound and I’ve cleared out any debris in drains around the scuttle panel, I’ve also had wheel arch lining off to check no drain always are blocked.
On looking harder and might be totally not connected, why would a metal bracket under the dash away from the screen be corroded? Is this just because of moisture in the vicinity due to the recent water leak.
Thanks in advance for any advice
