Hi all,
My new to me T6 has a 10L water bottle under the sink in a cupboard and has an plastic ‘bung’ in the top through which the pipe to the tap sits (with the pump in the bottle obvs). Also has a blue screw cap but that obviously can’t be fitted when the water pipe is in the bottle. When there is water in the bottle some splashes over the top when driving so I assume you’re supposed to remove the pipe and fit the screw top when moving around. Then you’ve got water dripping out of the pump on to the floor. What do folk do - take the pipe out of the bottle and open the tap to let the water run out or is there a way of keeping it connected without it splashing over?
