VW T6 Gas strut problems
PhilT
Previously fitted 1250 struts to hold a bike rack + bikes.
I have fitted a new strut to replace a strut that started shooting off under pressure (the lower attachment). The new one is doing the same, it's dangerous and knocks the rear light module off. Has anyone had this issue? Could the knob on the van be damaged??
Is the clip back in place fully on the end fitting of the strut?
Is the end fitting on the strut definitely the right diameter?
Not sure there is much to go wrong on the van end. If it looks like a complete ball it should be OK.
Thanks, yeah it looks the same as the other. Clip seems to fit right.
It is such a simple attachment I can't work out why it is failing.
I guess you have checked the total weight of the bikes is within the rack specification? Most e bikes are very heavy.
Did you manage to remedy this? Mine popped off the bottom and broke my rear light cluster.
I took the clip off and bent it slightly and now the bottom seem to be holding better but the two top ones can be pulled off by hand easily.
