Victron Solar MPPT 70/15
SamD
Not sure if im going mad but i dont think my solar controller is working correctly. Both my bluetooth battery monitor and my autoterm planar heater screen are reading around 12.6/7 but the victron is up at 13.82V and is in float mode and i dont know why!
I have the same Smart Solar MPPT 70/15. Assuming this is charging the leisure battery. I notice that the Load is in the off state, which I assume means the loads such as the heater are coming straight from the battery. I can’t remember if the load voltage is regulated as I link this to a 65A battery protect. A couple of questions:
  1. Are the 12 volt loads coming straight from the battery at the moment?
  2. Are you sure the heater and battery monitor are not connected to the starter battery. (The reported voltage difference would indicate they aren’t, as it appears the loads aren’t connected to the MPPT)
  3. Are you using a victron Smart Battery monitor? If so, have you created a VE Smart Network?
Please post a couple of photos showing the installation and how it is wired.
Hi,
Everything is connected to the leisure battery, heater, fridge, lights etc.
The solar panel is wired directly to the leisure battery as well.
No monitor just using the information transmitted by the mppt.
Cant get any photos unfortunately as left the van for the day.
Going to look more into it when i get home, just confusing me as it was fine last season.
