Good evening gents, I'm trying to understand where my shunt goes in relation to my leisure batteries does this look good so far, knowledge appreciated.
It needs to go between the negative terminal of the battery and everything else connected to ground. So there should be nothing connected at all between the shunt and the battery such that no current flow can bypass the shunt. Your diagram looks about right from what I can see.
In your diagram the output from the Redarc is connected directly to the battery negative and will bypass the shunt so the Victron won’t be aware of the charge going into the battery.
Gents thanks, mm better sort that I can only thank you guys, so just to make this clear the negative from Redarc should connect to the output side of the shunt and not battery?
