hi i use it all the time never had a problemGreat job your doing there JE. looks great well done and a nice neat finish. And Cheers Spook been looking at Megavanmats for the dark blue but there Glue is 100 degree melt against the 120 degree but they are very helpful and friendly i contacted them about some off cuts . i just cant make up my mind for what colour ... ocean, pacific, or dark against my acapulco van .. not having windows but a lot of lighting.
HI I have just done my van 1st attempt , I used easy 4 way stretch & the color silver to keep the intera light , I wanted to do it as removable panels , the wheel arch is a bit more tricky & around the window , & its not quite as easy as they show you ,they have the advantage of doing many ??? It gives you great satisfaction when you do it your self , Here's a few shots how I done it & work in progress View attachment 64188 View attachment 64189 View attachment 64190 View attachment 64191 View attachment 64192 View attachment 64193
Hi TB most people like a smooth full panel finish without showing the fixingsGood evening,
I am just finishing of the silent coat and insulation and will be ordering some carpet as soon as I get a sample card through and decide on a colour!!
I noticed that you carpeted around the wheel arches with smaller pieces of carpet but then later pictures show the same areas carpeted to the ceiling. How did you join the pieces as it looks quite a clean join from here!!
Cheers.
sorry good luck with your conversionHi TB most people like a smooth full panel finish without showing the fixings
, but I wanted separate panels & fill the in between bits separate, so I can gain access at a later date if needed . Here is progress so far with all the button fixings now pushed fully & the start of the wiringView attachment 64561 in which I Am more that please with For my 1st attempt ,
Thank you.Hi TB most people like a smooth full panel finish without showing the fixings
