Thanks. I’m trying to find out thro VANWORX. Eg what make is the system, if a new remote can be purchased were are the components or connections located to be able to test or a circuit diagram but no response. It’s a original cost was£500 , lol so I’m expecting Blackpool type moodlighting. It never worked with previous owner. Can’t contact original purchaser. ThanksLED are are sensitive to polarity. They work connected one way + or - and not the other way around, - or +. If that makes sense. some times switching terminals around might work. I can not advise further than that, only kinder garden stuff I am afraid.
it is infra red and it appears to be working inasmuch looking at it thro a iPhone camera lense, but does not operate the moodlighting. When switching system on switch is lit up and moodlighting flash or flicker once and that's it. Pointed remote all over the place but no result.Not much detail, but you mentioned a remote?
Normally these remotes have infrared so you might need to point it in the direction of a very small receiver?
Can you post a picture of the remote?
Thanks for reply. Any idea were controller is sited? Could you post an image of it?I've got one of those the receiver is tiny and might have gone back behind the trim.
If you find the controller you can then test.
Also, if you suspect the controller, I have an old one I could post you.
Is it a strip LED then its probably sited close to the start of the LEDs
If its an Infra red transmitter you should be able to see the controller. Or at least the IR receiver part. It will probably look something like this:There are 3 strip LEDs that we can see one under bed seats, one in roof above seats and one in cubbyhole hole above sink. . Don't know if there is anymore these e the ones we have notice that flicker flash as we switch on. Don't seem much for a £500 installation lol? Would just like to see it working ! Have van just two months so still fining way! Thanks
Let us know what you find when you have the van back. (or don't find lol)Thanks for that will scour the interior at weekend. Van is in paint shop at mo having repair to front wing and new door hinge due to gales two weeks ago blowing door wide open. Thanks a lot for your input.
Let us know what you fid when you have the van back. (or dont find lol)
Yes thanks. Happy with that lol.Glad it’s sorted rather than being a big problem.
