Opie have some very good deals, I aways search on lowest price and they are often there or very close.I buy Castrol edge from Opie oils
I don’t think anybody other than people working in oil sample analysis are really going to know which oil fares better.Anybody had experience with Valvoline or Miller's oils?
Guy,The Millers is good, made in Yorkshire. The Valvoline is good, as is the Castrol. I also rate Fuchs as well which made the Quantum used by the OP.
To be honest, as long as it is a good reputable brand, meets or exceeds the right specs for the vehicle, you are good to go.
Cheers,
Guy
Awesome. Thanks @LozYou are correct, the extra half fills the empty oil filter, so buy a 1L bottle as well and whatever is leftover you keep for a top up between service.
Which T6 do you have? I will get the capacity updated.Thanks for all the replies. Been on the Opie Oils website and what a find! Never new it existed.
One question though, when you make up your own service kit and select the oils you want. It gives 7 litres. However I thought the T6 took 7.4 litres or have I read wrong
Thank you. I have the 140 bhp version with engine code of CAAC.Which T6 do you have? I will get the capacity updated.
Cheers,
Guy
Totally agree, I've previously run two cars to over 200K miles by changing the oil and filter more frequently than specified and using any oil that met the required spec, often Halfords own or whatever was easy to obtain and cheap. Neither car ever had any engine issues.I think frequent oil/filter changes is key, especially if you DIY like you are.
I’m not quite convinced we need the best oil money can buy for a 2.0 diesel.
But one day I’ll run my Mustang GT500 on Millers/Fuchs/Mobil1 etc.
*lottery win required
Fuchs is a great oil, so you will have nothing but good results using it.So I'm coming up to my 2nd DIY oil change (1st using Castrol Edge) and I thought I'd do some research.
Found some youtube vids by Piotr Tester.
I'm not sure what to make of it. I understand the principle of him testing the friction between metals but not sure how well this realtes to real life engine wear.
Anyhows I then found his Motor Oil Comparison page on google docs.
This guy is obviously passonate about oil!
Interestingly the Fuchs oil shown in the video above scored really well in his tests compared to other oils that also meet the VW 507 spec as recommended in this and other oil threads on here.
So I've bagged myself 15 litres of the Fuchs for £80.97 delivered on eBay which is enough to do 2 full oil changes.
Happy days.
A bit worried about it coming in the faff of a wine box as mentioned by @Paynewright in this thread but for a tad over £40 per oil change I'm sure I'll manage.
Luckily I've got an empty 10l adblue drum which I'll use for disposing the old oil so at least I won't have to faff about getting it into a wine bag.
So what do we thing about these tests? Fact or friction?![]()
Just purchased 8 litres of Fuchs TITAN GT1 PRO C-3 XTL 5W-30 Fully Synthetic Engine Oil from Opie oils, ready for an oil change. Had a discount code too, so a bonus as well.The Millers is good, made in Yorkshire. The Valvoline is good, as is the Castrol. I also rate Fuchs as well which made the Quantum used by the OP.
Cheers,
Guy
