Sold Used Bilstein B14 T32 Kit. £500
Montecha
VCDS User
As my van‘s become more of a Camper, I’ve found I need a higher ride height, so I’ve just taken the Bilstein B14 kit off.
The kit is for a T32, it’s 3 years old, probably about 25k miles - not much of that in the last 18 months. My van was a Kombi daily driver, so not carried load at all.
The kit works best with Panel/Kombi vans if you want the full height range (40-70mm drop), heavier Camper vans seem to sit lower. With my Camper set up I ended up 380 mm (F) and 380 mm (R) from hub centre to wheelarch.
£500 ono
Located at RG9 (Henley)
Jamie
Picture added includes the two C spanners that are not shown.
Was all good when it was taken off no knocking no leaks etc.
Mine went very quickly on one of the Facebook T5 pages.
If you or someone you know is on Facebook its worth a punt.
Back up For Sale, as sadly the deal fell through last minute.
The kit works best with Panel/Kombi vans if you want the full height range (40-70mm drop), heavier Camper vans seem to sit lower. With my Camper set up I ended up 380 mm (F) and 380 mm (R), from hub centre to wheel arch.
£400 ono, collected. Located at RG9 (Henley)
(I can pack and drop with a courier but buyer will need to cover cost)
Jamie
