I'm going to install an underslung tank but im looking at pump options. I've got no room in the van, or at least i dont in the rear quarter. Has anybody mounted a shurflo pump under the van with long term success? Not sure im so keen on adding another 2 holes to get a submersible in the tank and i like the idea of having a positive pressure system to have a shower hose mounted externally also. it means i can run direct into the pump then run water into the van but also have an external outlet.
If so where have you mounted to keep it protected and has it survived the conditions.
TIA
TIA
