Unable To Code Westfalia Tow Bar Without Park Assist
bullracing
So I have followed everything, all installed, coded trailer 69 into installed list but I am unable to connect to the controller.
From reading I then need to code park assist but I have no sensors so I am unable to do that.
Any ideas what I should do?
If you don’t have park sensors then you don’t need to code them
If you are unable to connect to the new module then it’s prob not connected correctly, the module will need a power pair and a CAN pair correctly connected to be able to talk to the van
Are you seeing faults when you scan the van ?
Thanks Pauly. Sorry I had to sort and get going with the trailer Saturday. So with you saying that I find no power at the fuses. The large cables joined together under the seats, when I split them individually they had no power and only took power from one of them. I had to join them back up and then put 3 tails on them. I will get the westfalia extension fitted this week which should sort it. Once I done that I had power and boom, all sorted. bloomin thing. what a faff. Me being in a rush did not help the matter at all.
