Turn off Stop / Start
I commend your effort and comprehensive write up but this seems a bit of an extreme job to achieve this result.
I have disabled start/stop on my vehicle using VCP, this does it electronically in the ECU and is extremely easy to carry out, i have been unable to recreate the results using VCDS but have yet to apply myself to this
There is a device you can buy for circa £30 of ebay that connects to the back of the switch and will simulate a button press everytime the vehicle is started, yes theres an expense to it but will save time routing/connecting cables which i suspect will be beyond the average user ?
Sorry im not trying to talk down your mod i actually think its pretty ingenious but for the average forum member i think there are better ways to go about it
Hey Pauly
Sorry to drag up an old thread, but I have access to VCP and would like to disable the Start/Stop and knowing there’s a lot of damage to be caused messing with VCP thought I would ask for some help
TIA 🙏
Just to be clear mine was a T6 and on VCP there is one click function (OCF) that does it for you
If you go into the OCF section you cab select the vehicle/function you are after and it should all be there for you
