Top mount moving
Adam H
Anyone had creeking noises coming from the front when at low speed or maneuvering ? for example parking and turning the wheel and horrible creeking noises.
Had a look today and got the front wheels off the floor, turning the wheel you can hear and see the top mount rubber ( from the under side ) moving and making the noise. They are new Meyle HD ones fitted a few months back with Air suspension. Had the scuttle bay open and nuts on top are super tight, also its got the correct original top mount nut on like it should.
Anyone had it, I assume its just a case of replacing the top mounts again, Which while we are at it i'll also do the drop links again and ball joints as i dont think the ball joints been done ever.
When you say it has the original top mount nut on like it should .... where is it ?
In number 9 position I believe, I didnt fit them personally but in a few weeks its going back, new top mounts and double checking everything to see if we can see why its doing it.
@Geordman did you find a solution to your noises as I have similar - I have changed to poly bushes for the abr and the wishbone and replaced the top mounts all in one hit as everything was tired on my van but have this noise that really bugs me at the moment....
