TMR location - Issues after unplugging nearside headlight
uv101
Hi All, I have a T6.1 with non LED headlights that I've fitted spot lights to which are working fine. I have picked up the supply to the high beam on the nearside headlight (RHD) and have a 1/2 second delay relay governing the main spot light relay. The effect is that a flash less than half a second doesn't flash the spots but when you go on high beam or hold the flash, the spots illuminate after 1/2 second. Thought that would stop me blinding other road users most of the time :)
I've also had the front bumper off to fit the spotlight brackets.
However, I believe I've disturbed some wiring in the process and now I have several fault codes relating to Start stop, Hill Hold, Front Assist and parking Aid.
My guess is that I've disturbed something either removing the front bumper or getting hold of the plug on the nearside headlight to get to the high beam supply.
Looking at various parts of the wiring diagram, I can see that the headlight loom, front parking and the Adaptive cruise control unit are connected to the "TMR" TMR -Coupling point in engine compartment, right. That looks like a good place to start to me.
Does anyone know the exact location for the TMR connector before I start removing the bumper again?
Thanks all :)
