Multiple Mag Mount or Multiple Suction Mount.I still have my Amateur Intermediate Radio Licence, used to have some kit in my old Defender!
Problem with the Transporter would be installation of an aerial damage free?
Still have a CB and a couple of handheld 144/430’s which I should dig back out.
I’ve tried these before, but could never get a good ground without either puncturing the paint or scraping some back, rather not do that to the transporter. Maybe a mag mount might be worth a try…I'll use a boot-lip mount on the top edge of the tailgate.
picture pls?I'll use a boot-lip mount on the top edge of the tailgate.
Leave it with me, as soon as it's done.picture pls?
So no steel on top surface of your truck. Is their a rack on top of the pop top? If so could attach a steel sheet or plate across the top of the rack and attach the aerial direct or via one of the mounts that I mentioned. Suction mounts will adhere to windows. I am mainly thinking when stationary. I m unsure of its intended usage.Sadly a fibreglass pop top precludes mag mounts, and solar panels and suction mounts aren't compatible with solar panels.
I'll post a pic of my solution once it's done.
I thought your licence had expired, that must have been someone else then, over, What sort of frequency might that radio operate over then? Does a ham licence cover all ham frequencies? I take it these days morse is not a requirement?Er, no. I'm a ham op, not a CB'ist.
Thank you for the explanation.My licence hasn't expired, although until now I'd been inactive for a couple of years.
It a dual bander, quite a wide VHF and UHF range. Bought it some years back because it was small enough to live inside the centre console armrest on my Xc90.
Morse is no longer a requirement for HF, and that's probably sensible. In days of yore morse was about it, no phone or data modes, so if you strayed off band or caused QRM then anyone complaining would be contacting you back in morse and you'd need to be able to understnd it, but no more.
And with a few minor exceptions, all licenses cover all ham bands, albeit with different power levels for differing licences.
The tailgate. It's not so critical on VHF, even less so on UHF,What does the antenna use for a ground plain or is that frequency dependent?
