T6 problem
Markus16
Hi new to this group i have a t6. 2016 its been parked for about 10 months came to it yesterday and it won’t start, i have no electric windows, no central locking, no lights at all including hazards indicators etc it does turn over and there is diesel at the injectors hopefully someone can help with this problem please
Try with the other key.
Check for any forgotten alarm/security device.
Just my 2c.
For the fault itself, the first thing I'd check is the battery and battery connections. A battery can sometimes have enough power to crank the engine but still have low voltage or poor connections that cause multiple electrical systems to fail. Also check:
  • Main battery terminals for corrosion or looseness
  • Main fuses/fusible links on top of the battery
  • Earth (ground) straps between the battery, body, and engine
  • Voltage at the battery (should be around 12.6V with the engine off)
The combination of no windows, no central locking, and no lights suggests a power supply, fuse, earth, or body control module issue rather than a fuel problem. If you can post the battery voltage and whether the dashboard lights up normally when the ignition is turned on, that would help narrow it down.
Hi thank you for your reply I've got it running fine now with all electrics working, but now my dash says check safe lock I've got no central locking my passenger door is stuck shut i have to open each door separately by inserting the key into each door
You're in a much better position now.
How did you get it going?
I don't think locks are known to fail. However, have you put any insulation in the doors?
The previous owner put Rockwool in mine and it played havoc with the latch mechanism.
