G Gazvdoubleu New Member 19 Jul 2025 #21 how easy is it to upgrade a t28 to a t30 and how much cost roughly, tia
manfrotto Senior Member T6 Legend 19 Jul 2025 #22 @Plastefuchs do you have the build sheet with all the codes on it?
P Plastefuchs Member 21 Jul 2025 #23 manfrotto said: @Plastefuchs do you have the build sheet with all the codes on it? Click to expand... @manfrotto - Got the full list from the carvertical report Attachments Van spec sheet.pdf Van spec sheet.pdf 2.6 MB · Views: 15
manfrotto Senior Member T6 Legend 21 Jul 2025 #24 Plastefuchs said: @manfrotto - Got the full list from the carvertical report Click to expand... It has the weight code of 0WQ which states: Gross Vehicle Mass (GVM): 3,000 kg Payload: 1,131 kg Tare Weight: Approximately 1,869 kg Braked Towing Capacity (12% Gradient): 2,500 kg Unbraked Towing Capacity: 750 kg
Sasquatch Largest Land Predator in the Midlands VIP Member T6 Legend 21 Jul 2025 #25 Gazvdoubleu said: how easy is it to upgrade a t28 to a t30 and how much cost roughly, tia Click to expand... For a couple of hundred quid a T28 can be up rated as high as 3.1t.
mightythings Kiwi member T6 Pro 22 Jul 2025 #26 manfrotto said: It has the weight code of 0WQ which states: Gross Vehicle Mass (GVM): 3,000 kg Payload: 1,131 kg Tare Weight: Approximately 1,869 kg Braked Towing Capacity (12% Gradient): 2,500 kg Unbraked Towing Capacity: 750 kg Click to expand... Very helpful! Thanks for this info. Tracked down my van’s GVM code as above and it indicates it’s a T32!! Well happy.
mmi Senior Expert VCDS User Moderator VIP Member T6 Master 22 Jul 2025 #27 manfrotto said: It has the weight code of 0WQ which states: Gross Vehicle Mass (GVM): 3,000 kg Payload: 1,131 kg Tare Weight: Approximately 1,869 kg Braked Towing Capacity (12% Gradient): 2,500 kg Unbraked Towing Capacity: 750 kg Click to expand... Have you got a reference to decipher the code?
manfrotto Senior Member T6 Legend 22 Jul 2025 #28 mmi said: Have you got a reference to decipher the code? Click to expand... These are the PR codes for GVW's 0WAZUGGross vehicle weight rating0WBZUGGross vehicle weight rating 3.2 t0WCZUGGross vehicle weight rating 3.5 t single tires0WDZUGGross vehicle weight rating 4.0 t0WEZUGGross vehicle weight rating 4.6 t0WFZUGGross vehicle weight rating 5.0 t0WGZUGGross vehicle weight rating 5.6 t0WHZUGGross vehicle weight rating decreased from 4.0 t to 3.5 t0WIZUGGross vehicle weight rating0WJZUGGross vehicle weight rating 3.5 t dual tires0WKZUGGross vehicle weight rating0WLZUGGross vehicle weight rating0WMZUGGross vehicle weight rating0WNZUGGross vehicle weight rating0WPZUGGross vehicle weight rating0WQZUGGross vehicle weight rating0WRZUGGross vehicle weight rating0WSZUGGross vehicle weight rating0WTZUGGross vehicle weight rating0WUZUGGross vehicle weight rating0WVZUGGross vehicle weight rating0WWZUGGross vehicle weight rating0WXZUGGross vehicle weight rating0WYZUGGross vehicle weight rating0WZZUGGross vehicle weight rating From the build sheet on my van it has 0WQ which specifies it is 3000kg: Also, in the "upgrade" options available here in New Zealand when my van was new they also had the following : Increase Gross Vehicle Mass to 3,200kg, 16" Steel Wheels (Not valid for 146kW & 4MOTION) PG1 $1,800 Increase Gross Vehicle Mass to 3,200kg, 17" Steel Wheels Bur these don't appear in the list above ! We probably need others with T28's and T32's to confirm what their PR code is.PG2 $3,000
