T6/T30 LWB Suspension Woes
Pilchy
Hi!
I have a 16 plate T6 LWB T30 thats been converted with a pop top/kitchen/RNR bed etc. The previous owner installed a STANCE+ SPC094 suspension kit which from what I can tell, might not have an adequate spring rating for the weight of the van. The rear suspension is heavily compressed at idle. It bottoms out quite a bit. The front looks like it might be corroded damaged. I wanted to get a second opinion on this before I commit to upgrading the front and rear shocks/springs. Images attached. Mainly want to know if this is even safe to drive at the moment.
Lastly, should I get a full upgrade, some recommendations on a kit would be great - not massively interested in being able to adjust height, just looking for ride comfort. I've had a browse through the forums and often Koni/H&R popping up a lot. I've got the van in for a flywheel/clutch replacement on the 13th - would be looking to tack the suspension on then as well, so preferably any products that I can get delivered to south of the UK before then would be grand.
Cheers!
Welcome to the forum. Have a search through the forum as this has been covered many, many times. There are numerous options depending on your budget and aims ranging from using T32 springs to full replacement coil overs or even air.
There are a few trusted specialists on the forum who can advise, supply or fit as needed. Hopefully one is near you. Ones that spring to mind are CRS Performance, The Van Cave and Bognor Motors. All are active on the forum.
