T6 headlight washer issue
Delpel1
Hi all, I have a 2018 T6 Kombi with Led headlights and headlight washers. My issue is the passenger side washes every time I wash the windscreen. Lots of fluid that fires straight up when the van is stationary and on the headlight when moving. The drivers side works as expected ie, first wash after ignition on and every 5th wash.
Any thoughts and is there a process to check them out.
Cheers Derek
Normally the LED factory headlight washers will go every fifth pool of the stalk as you say.
And normally only when the headlights are switched on.
If the other side is going off every single time then that's not quite right.
Maybe try a battery reset first?
