Why does this not go away? It is very distracting, I have to take the battery lead out to prevent it from going flat due to hazard warning lights. Is this a fault or something else?
It's a Volkswagen T6 Transporter 2017, again the safety lock warning does not go away when the ignition is on and the hazard warning lights just don't go away at all, do you think they are related, and if not, why?
It's clearly a fault. If you have a way of reading error codes, then post them on here, otherwise you need to find someone to fix it.
Where in the UK are you based ?
