T6 central locking module help
Power ut
RSQ3 engined
I have 2 door modules from either a t6 or t6.1 which I have the plugs but there all white wires
Looked in download section but unsure on pins
Anyone up on the 8 pin plugs ns os need to get my van on
What do you need to know exactly? If you're swapping like for like then they should just plug in.
What are the part numbers you have?
If the wires are white it's a T6.1 door module. IIRC you have a T6 BCM which I'm not sure these modules will work with. Here is a diagram of the passenger side. The white wires go to the door coupling point TTVL. The pin numbers are on the drawing. eg T17aj/1 is pin 1 on the 17 pin black connector in the front door coupling. Usually pin 1 and the last pin numbers are stamped on the connector, you might need a magnifying glass to see them though. Its also very common for VW to use pin 1 for the earth connection. Look at the central lock unit. The only none white wire is the earth which is in pin 1
