T6 6pin sliding door contact vs T6.1 8pin contact
Raytech76
Hello everyone! Greetings from Norway. Does anyone have the schematics for the right sliding door, 6pin T6 vs 8pin T6.1? My old door have 6pin and the new have 8pin, but uses only 6. I need to use the 6pin because of the 3pin door contact connector, but the wiring colors are of course not the same.
I've done the reverse. Removed a damaged door from T6.1 and replaced with the older door which has a 6 pin contact. I'll look through the same links.
Currently there is always an error if door open.
I can't easily change the locks because the rear lock has the bolts through the door at a different angle and the bolt pulls don't line up.
