T6/6.1 front passenger seat isofix retrofit / swivel
petr_io
I have a T6.1 (Cali Beach) with two seats in the front (heated, non-swivel). While I have isofix on the rear triple bench, I do not have ISOFIX on the passenger seat in the front. I still do have all the switches to turn off the passenger airbag etc.
Is there a way to add isofix to the front passenger seat? Is it a part that's missing and can be added, or is this something more substantial that requires a different seat altogether? I also have an extra single sixth seat in the rear, which does have isofix on it, should I be able to take the parts from it and put it onto the front passenger one? I would be willing to sacrifice the heating function to get the isofix (as there is little point in heating a seat with a child seat in it)
Speaking of the front passenger seat, which swivel base would you recommend that would also maintain the heating functionality?
Thank you!
Probably a different seat altogether for the iso fix.
As for heating a swivel will have a hole at the pivot point and the cable should be long enough or easy to reroute and reconnect. If not a simple extension cable can easily be made up.
You can’t retrofit IsoFix. It’s two loops of solid metal welded onto the seat frame.
Most cars don’t have isofix mounts in the front seat.
