T6 140PS 6 speed clutch master-cylinder replacement [Guide]
Chrishall888
Hi folks,
I’ve changed the master cylinder today on our T6 140 6 speed and noticed it has not been published before.
Hope it helps:-
1: open the bonnet and remove the wiper arms. These can be stiff but with a wiggle up and down usually frees the off. If problematic get a small puller.
Pull the seal off and the wiper cover pulls off B74E6154-7BB2-4FC7-8F48-B7B2B00D0EA5.jpeg
2:securing a harness is a double threaded bolt with a 13mm head. Remove- this olds the top of the clutch pedal.
3: when you’re under the bonnet, pull the supply pipe off the side of the brake/clutch master cylinder
4: with a long nose set of pliers, release the silver clip retaining the clutch supply hard pipe from the master cylinder. The clip stays in place and withdraws 10mm or so.
The pipe, with a little tug comes out the bottom of the cylinder.
5: under the dash, release the kick panel from the clips. You don’t need to separate the column cover from the upper cover, as it comes out in one peice.
6:remove the brake and clutch brace: 2x 10mm nuts. Only need to slacken.
7:release the lower nut:13mm
8:release the right nut to bulkhead and electrical harness.
9:depress the clutch slowly and remove the whole pedal assembly.
10: on the bench: release the supply pipe and remove the foam packing
11: using two screwdrivers, release the white clip from the pedal.this is a tricky bugger but persevere, it comes off!
12: release the 2x mounting bolts (13mm) and electrical harness
13: remove the cylinder.
14: instal new cylinder and reattach pipe and foam.
15: install foot pedal to van and reverse the above procedure.
16: top up brake fluid and place gear selector in 4th.
17: with assistance bleed clutch.
Hi Chrishall888,​
Great instructions except that I can't get the clutch supply hard pipe out. I've withdrawn the clip the requisite 10mm but it seems solid in there.
I have actually disconnected everything else and all is loose.
I've tried gripping the hard pipe and getting a screwdriver between the plastic and pliers and twisting but it doesn't seem to want to budge, any ideas?
I was a mechanic in my earlier life but I suppose I'm getting on a bit now
Hi Chrishall888,​
Ah the bloody oring can get a good hold in there!
Spray it with some wd40 or lube and give it a tap upwards with the plastic hammer, as close to the bend as possible.
I wouldn’t suggest using a screwdriver or such on the collets, as they will be quite brittle and potentially crack if touched!
Thanks for this guide.
Can you give me the part number for the master cylinder?
Hi, does anyone know the differences if any between 7E0 721 401F and 7E0 721 401E...
Been looking for a new Master Cylinder, and can find a Valeo part for a Transporter at E level, but unable to find anything for F... The difference is £46 for E to £126 for F so if it is just an upissue for Supplier change i was wondering if they were interchangable?
Just wanted to add to this excellent guide by Chris, that I have just used.. Thank you!
The bleed point for the clutch hydraulic line is on this block, which also acts to limit the speed of the fluid flow. It's just outside of the clutch housing. It needs a 1/4 turn to open. It is very stiff and needs a 13mm spanner or AJ on it. Space is tight and it's a pain in the hoop! Someone on another thread suggested pulling the clip out of the nylon part to make it turn easier. Do not do this! If the nylon part pops up you'll be in a world of pain and will not be able to sort it without removing the whole valve and nipping it all back together in a vice. Speaking from bitter experience!
Also, I would say that it's a good idea to have some spare o-rings/seals for the pipe connections in stock before you do the job.
OEM part number below. Also available in bulk packs from Amazon
1K079874​
