T6.1 switched live pick up (CTEK 250SE) from internal fuse panel, drivers side
Realers
Hi,
Having trawled the forum, and probably looking for a simplistic reply, I am struggling to see whether anyone has answered the following question. What is the equivalent fuse position to that quoted for the prior fuse panel in the central position - "5th fuse down on the right hand side"? I have attached a photo of my drivers side fuse panel. Thanks in advance.
Please excuse my ignorance of the CTEK 250SE but is it not more correct to use the 'engine running' signal from the BCM for this purpose?
Rod,
You may well be right that a signal from the BCM is a better option. However due to my limited knowledge base of car electrical systems, I would not know how else to pick from the BCM. The CTEK manual only states to pick up from "+15 clamp", I have seen installations on you tube where they use a piggy back fuse holder to pick up from a 5 amp fuse, but as mentioned, the videos refer to a fuse panel in a different location and apparent layout. Thanks.
