T6.1 genuine digital cluster
DanW81
Hi there folks, can anyone know or confirm if a digital cluster removed from a t6.1 transporter van thats mileage is lower than the van it is to be coded to can be done?
I am not 100% certain if you can roll the mileage up. I know you cannot go backwards, which makes sense.
Again, from what info I have managed to get it seems that you need genuine odis to register a new cluster (makes sense) but if using a preregistered one, vw require 48hrs to confirm not stolen.
Again not sure if this is correct, odis can not change the mileage on a cluster unless brand new. It requires software from the likes of aribtrites or similar to change.
Been offered a digital cluster from a non stolen t6.1. Genuine reason for the seller removing.
Any help always appreciated
Dan
Dug a little deeper.
So approval from vw first, then third party software to correct mileage on the bench from my original cluster to new one.
Sounds like more hassle than it's worth. Great if you have this software I suppose.
New it is then😅
