flat4power
Hi all
I'm french
I own a VW T6.1 without folding miror
I buy the retrofit kit to add this feature
When I reprogram with the dongle I have good working of all joystick command (move miror, defrog ...) the only issue was with automatic window up and down because I have change driver ans passager controller for the folding option
I do the annual revision to VW and they recode new controller and now I have automatic up and down for my window
BUT ....
joystick to move my 2 miror is not working like defrog position (only folding miror position of joystick is working)
They don't what they have do and they say me , they have no tool like vcds to proceed to a recoding
I try to put my old controller to test if my original coding of controller can resolve this issue but not
I think this coding for joystick is somewhere but I dont' know where
And now in vcds I only see driver door control module not passenger module, is there an possible issue on my can ?
Can someone help me ?
I'm french
BUT ....
Code:
Sunday,30,March,2025,13:13:23:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.0.2 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250228 DS364.1
www.Ross-Tech.com
VIN: WV1ZZZ7HZPH089803 License Plate:
Mileage: 30173km-18748mi Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 15 17 19 20 22 44 55 5F 69 75 D6 D7
VIN: WV1ZZZ7HZPH089803 Mileage: 30173km-18748miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
75-Telematics -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DMZA) Labels:. 05L-907-309-V1.clb
Part No SW: 05L 906 023 MR HW: 05L 907 309 AD
Component: R4 2.0l BTD H80 2582
Revision: NBH80--- CVN: 29E7E1DB991E9EBCA3C795CF64CF85E9A3C795CF43FB2DAA
Coding: 002500340336050800000000000000000000000000000000
Shop #: WSC 00012 790 00018
ASAM Dataset: EV_ECM20BTD01105L906023MR 006001
ROD: EV_ECM20BTD01105L906023JC.rod
VCID: 04518C0D2E98E1FAAB9-8050
VINID: 9E606AAAA1D8AA06002092000CC9918B52
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DV 300 012 B HW: 0GC 927 711 H
Component: GSG DQ500 H06 3702
Revision: 00H06V15 CVN: D00EAF6B
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021.rod
VCID: 323D1AD5C4AC9F4A495-8066
Address 03: ABS Brakes (J104) Labels: 7LX-614-517-V1.clb
Part No SW: 7LB 614 517 B HW: 7LB 614 517
Component: ESC_base H01 0800
Serial number: 08501513230421
Coding: 30554752C84FEE8E0C5CE2A413697726383027BC
Shop #: WSC 17873 123 50804
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
VCID: 3FDB43E107FE4222B6B-806A
Address 08: Auto HVAC (J301) Labels:* Redir Fail!
Part No SW: 7LA 907 426 K HW: 7LA 907 426 K
Component: AC Manuell H01 0701
Coding: A03010000810030001000800504001050000000000000000800000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: EV_AirCondiBHTCVN54XT6PA_VN46.rod
VCID: 4BC367314346EE822A3-801E
Rear air conditioning block 1:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 2Q5 937 090 C HW: 2Q5 937 090 A
Component: BCM T6PA Std+ H12 0963
Serial number: 02102314900548 Dataset Number: V03935404HJ 0001
Shop #: WSC 52771 006 1048576
ASAM Dataset: EV_BCMA0 208001
ROD: EV_BCMA0_207_VW37.rod
VCID: 372B2BC12FCE7A627EB-8062
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S5Y23M05D24H19M55S29
Coding: 0018DD
Driver door control module:
Subsystem 2 - Part No SW: 7L2 959 405 B HW: 7L2 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000074463369
Coding: 130007
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H10 0075
Serial number: 000150058323148 Dataset Number: V03935313KK 0001
Coding: 8471151111
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000_009_SK25.rod
VCID: 53F37F519B76B642623-8006
Address 15: Airbags (J234) Labels:| 2Q0-959-655.clb
Part No SW: 2Q0 959 655 AN HW: 2Q0 959 655 AN
Component: VW22Airbag 020 0511
Revision: -------- Dataset Number: V03935346ZR 0001
Coding: 8800C000000000007C0001CF000C40030065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 094F9D3909BABC92D8F-805C
Address 17: Instruments (J285) Labels:| 7LA-920-XXX-V1.clb-SRI3
Part No SW: 7LA 920 741 A HW: 7LA 920 741 A
Component: KOMBI 202 8500
Coding: 07A50A0A2180000801087A001401000080600000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
ROD: EV_DashBoardVDDMQBAB_VN46.rod
VCID: 3C2134ED16E8593A939-8068
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 G
Component: GW MQB High 527 5504
Serial number: 28042310801513 Dataset Number: V03935367RM 0001
Coding: 0B0100344F056A0401100048100F00010001070000000000000000000000
Shop #: WSC 00012 790 00032
GVL: 01C43C0000000100C00010008000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_SK25.rod
VCID: 7F5B03E1477E8222F6B-802A
Generator:
Component: 5-00-15-00-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 3G0 959 442 AH HW: 3G0 959 442 AH Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H50 0500
Serial number: PR6-0440036133230094
Coding: 280C00
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 7E0 915 181 N HW: 7E0 915 181 N
Component: J367-BDMConti H03 1052
Serial number: 773433020023042704B1
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 7C0 907 155 HW: 7C0 907 155
Component: U13DCAC H05 0870
Serial number: A168555
Address 20: High Beam Assist. (J844) Labels:* None
Part No SW: 565 857 511 B HW: 7E0 857 511 C
Component: FLA H10 0010
Revision: AA001001
Coding: 040400E200000000000000
ASAM Dataset: EV_HighBeamAssisAU33X 001019
ROD: EV_HighBeamAssisAU33X_VN46.rod
VCID: 1D67D969AD323032847-8048
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 L HW: 0CQ 525 130 C
Component: Haldex4Motion H56 7822
Serial number: HA1-00017.04.23 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_VN46.rod
VCID: 4EC56E25B054DBAA4DD-801A
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 G HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7160
Dataset Number: V03935340DA 0001
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002015
ROD: EV_SteerAssisMNB.rod
VCID: 46D55605582413EAF5D-8012
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: -------------- Dataset Number: V03935338PG 0001
Coding: 0C8A020009200003
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_SK25.rod
VCID: 41DF4519710A34D2C0F-8014
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G5 035 820 M HW: 3G5 035 820 M
Component: MU-O-ND-EU H25 0330
Serial number: VWZAZ2B0841574 Dataset Number: V03935363RX 0001
Coding: 64600000000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_001_VN46.rod
VCID: 2E050EA5D094BBAA2DD-807A
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5NN 919 605 D HW: 5NN 919 605 D
Component: ABT_Std-2_Nav 285 8304
Serial number: VWZ6ZMB1155919
Data carrier:
Subsystem 2 - Part No: V03 959 817 SN
Component: EUR 2023 8073
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H0 907 383 C HW: 5H0 907 383
Component: Anhaenger H12 0058
Serial number: 000000000006218 Dataset Number: V03935309CF 0001
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001012
ROD: EV_TrailFunctGener3Hella_VW41.rod
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 284 G HW: 5WA 035 284 B
Component: OCUGen3High H22 0143
Serial number: 0000000304VIUQ7 Dataset Number: V03935344UB 0001
Coding: 06462000196898009005460160002607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW41.rod
VCID: 4ACD62354C3CF78A115-801E
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_001_VW41.rod
VCID: 6597B189C5E238F21C7-8030
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H08 9202
Dataset Number: V03935351ST 0001
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----(Elapsed Time: 01:20, VBatt start/end: 11.6V/11.7V. VIgn 11.7V)-----
---------------------------No fault code found.----------------------------
