T6.1VW
Dutch member
Hi Everyone,
my T6.1 was recently repaired after a pile-up, luckily only tin damage. I found out that since the repair the daylight lamps burn with the low beams. The flashing light function that switches between daylight and flashing light works the same, only with the headlights on??!
As soon as the car has been locked and the doors open with the remote key in the dark, only the headlights are lit, but as soon as the ignition is turned on, the daylight lamps also burn, but dimmed. Anyone an idea what caused this?
