there is a company working on it, however you will lose the sos button, plus you will lose all the settings on the headunit, like parking sensor volume/tone, mpg etc etc
Very few units will fit due to lack of space , plus there is no way to retain the usb C sockets yet
the T6.1 cannot have larger drivers in the doors so we use drivers that have larger cone excursion to help overcome the size issue. Then run one of our plug and play digital amps that can also run rear speakers , install sound deadening
then if you feel you do not have enough low end response add a Pioneer TS WX400da or Kenwood ps w8 active sub, these work well, many are a waste of money due to the size of the vehicle
or our Signature audio setup, using a mixture of Hertz and Audison . Based around our own design and manufactured underseat sub enclosure with a 10” sub
