T5.1 to T6.1 seats
cossie
As above can I change out my current T5.1 heated double bench for a T6.1 heated double bench? Are there any differences?
Cheers in advance
So according to the oracle that is chatGPT
Yes, the seat base and mounting points are the same, so a T6.1 heated double bench will physically fit a T5.1.
The thing to check is the wiring. VW changed parts of the electrical architecture on the T6.1, but the heated seat connectors themselves appear to be the same. Several members who've swapped between T6 and T6.1 heated seats report that the heating works plug-and-play with matching OEM heated seats and no coding required.
Before buying, I'd compare:
  • the under-seat connector(s)
  • seat belt buckle/occupancy sensor connectors (if fitted)
  • whether the donor bench came from a van with factory heated seats.
If the connectors match, I'd expect it to work. If they don't, you may need to swap part of the loom or adapt the wiring.
One final point: if it's a late T6.1 (2020-on) bench going into a T5.1 (2010-2015), I'd want photos of the plugs before handing over any money. Physically it's a straightforward swap, but the connector style is the only area likely to catch you out.
