DanRaistrick
Hello all,
I've just about completed my T5.1 to T6.1 conversion - however i'm having some trouble with the rear side lights and was wondering if anybody has experienced similar?
Everything works apart from the rear side lights - now i did have the rear lights repinned incorrectly on the first attempt (may this have caused a problem?)
I've had an auto electrician come out to sort the tailgate wiring which is all working correctly now using a relay and wiring into the interior back lights rather than back to the BCM.
The auto electrician also took a look at the rear lights and they did appear to all be working when he left (he said he swapped pins around for the fog light and side light) - until i turned the van on and put the full lights back on. Now the rear side lights are back off again and i've got a bulb warning on the dash
I'm getting a bit fed up of it all now as nobody in the area seems to want to touch it with wiring diagrams not being available due to going from the T5.1 barn door to T6.1 tailgate.
Any help or input would be greatly appreciated!
