T4 Airbag Light
Van Buddy
204 Kombi 4motion 2017MY
Trying to help out a friend with my vcds.
Airbag light comes on with ignition, blinks once and then stays on.
Clock spring checks ok.
Vcds is not seeing the airbag controller.
Any thoughts ?
Well, I think the airbag controller should have been listed.
E.g. in scans
Thanks for your reply.
It’s doesn’t show on any scan.
The connector to the airbag module was a bit dirty so have cleaned that with ipa, I’ll let you know how it goes.
Reactions: mmi
No luck. Same as before.
I’ll look tomorrow for earth problems and 12v feed.
Couldn’t find any obvious issues on the module.
Attempted a vcds scan and nothing is showing/recognised now. Flashes 29 times red then 1 green and repeat.
Tested on another car and vcds/laptop is all good.
Never had this problem before.
I disconnected the airbag module and I can now scan other modules. K1 is still short to ground.
  • Wow
Reactions: mmi
Once again, thank you MMI for nudging me in the right direction.
Non standard stereo was messing with K1 and I found a corroded/broken pin in the air bag module plug. I haven’t got a way of replacing the pin so I bypassed the plug.
All working as it should.
