Its be about 2400 miles since I last saw any adblue related issues on the van so just as I thought they had finally gone away, they came back to nip me again. When we set out on our current euro road trip, I looked at the MFD which gave an adblue range of 3500 miles and a recommended top up of 1.25 - 2.00 Gallons. That changed at some point over the next 500 miles to 3000 with the same top up recommendation.
All was well until about 700 miles into the journey when an amber spanner appeared which Carista indicated was something to do with a NOx Sensor (can't remember the exact fault!code) - I reset it with Carista, all was well and a 10009 miles later it's not reappeared on the MFD and Carista isn't seeing it either.
At 1469 miles, the now infamous '650 miles to no restart' orange warning appeared and the MFD showed exactly the same recommended top up (ie. 1.25 - 2.00 Gallons)
At 1496 miles the '650 miles' disappeared and a check showed that the predicted adblue range was 2500 miles again with the recommended top up still at 1.25 to 2.00 gallons.
The sh1t system installed by VW is bad enough but the least I would have expected is for that sh1t system to be able to do it's sums properly.
We will now just have to see what happens but on the plus side, at least we're on a slow return leg back to Calais, albeit more than 650 miles away if things go pear shaped again.
