Squealing when turning right
bully85
Getting a strange and intermittent squeal when turning right.
It can be very slight turn or full lock.
Doesn’t happen all the time but is easily heard from inside.
It’s not when I am breaking and it sounds to be coming from the front.
Any input would be useful.
Daft question, it's not always in the same bit of road is it?
There are a couple of surfaces near me that always cause a bit of tyre squeal like you get in car parks.
Is it related to extra load on the belt when you turn the wheel ?
If so could be anything on that belt .
Is the noise only when your rolling or when stationary.
If it's when rolling, is it there when cold or after a run?
When it is making the noise, will it go away if you were to gently press the brake?
Had this on a T4 - it was the steering rack that was on its way out. Might be different on T6 .
It only did it on the first couple of 'steers' after a cold start.
Rolling can be cold or hot.doesnt come on or go off with breaking.
