Thanks for the post
I dont have access to the van till next week.
I was a bit concerned about the 3 top coils all together
I’ve previously questioned the coil bound springs on another case. One of the expert suspension vendors / specialists stated that it is pre-load to prevent the spring being loose or falling out when the suspension is unloaded such as when the wheel is jacked off the ground.Thanks for the post
2" closer to the centre of the earth.................that cracked me up!I’ve previously questioned the coil bound springs on another case. One of the expert suspension vendors / specialists stated that it is pre-load to prevent the spring being loose or falling out when the suspension is unloaded such as when the wheel is jacked off the ground.
Looks like a sh4t engineering solution but if you want to be 2” closer to centre of the Earth and a few hundred quid lighter it’s the price you pay it seems.
Personally I’m keeping my standard shocks and spending the money on loose women, booze and drugs so I go all the way to Hell and not 2” closer with a knocking noise behind me2" closer to the centre of the earth.................that cracked me up!
