Short and imprecise answer is you can’t really rely on very much at all over winter. Yesterday was cloudy and overcast but dry and my 250w panel was trickling about 1amp in when I happened to look.
I hope somebody told Boris..........Solar is pretty much a lost cause in winter. The best you can hope for is to maintain an already fully charged battery with next to no power being drawn from the battery
Even though its less efficient during cloudy winter days you should bear in mind it is making a positive contribution.. and I would say over 6 to 7 hours of a typical winter day putting around 10 amps back in. Thats 10 amps more than without it...
10 amps on a typical winter day?Even though its less efficient during cloudy winter days you should bear in mind it is making a positive contribution.. and I would say over 6 to 7 hours of a typical winter day putting around 10 amps back in. Thats 10 amps more than without it...
I would agree with 10Ah. This is the solar yield from my boats array in the last few days. I’ve got 3 150w panels and its very negligible10 amps on a typical winter day?whats your panel J, a couple of kilowatts? At least the overhang will keep the van dry
(I think you mean 10Ah dont you... strange this should come up twice in 5 minutes!)
I've just bought the Ecoflow 220 watt portable solar array (got 50 pounds off, so it was £500). These are very good performers and well regarded, however they are still in their box as I haven't been bothered to link them up yet... I also bough the Ecoflow Delta 1300 from Costco for a miserly £885.00.Hi all,
Currently calculating my expected power use and therefore solar panel size.
So, a difficult and variable question, but hoping to take an approximate average.
What do you get out of you solar panels in winter?
Cheers,
I'm wondering if the EF Delta 2 would have been a better bet...I've just bought the Ecoflow 220 watt portable solar array (got 50 pounds off, so it was £500). These are very good performers and well regarded, however they are still in their box as I haven't been bothered to link them up yet... I also bough the Ecoflow Delta 1300 from Costco for a miserly £885.00.
I figured I can power everything I need in my vehicle - kettle, induction hob, toaster, slow cooker etc. from the power pack and then charge that with the solar array.
I don't have to worry about sub-par roof mounted panels which spoil the looks, hardly ever orientate towards the sun, can be a fire risk etc.
My van is clutter-free (ish) and has very little in the way of exlectrics to play up at a later date. I can also use the power bank and solar array anywhere I like.
This setup I think, has saved me around £1500 and a load of aggro on installation works.
Hope this gives food for though for anyone considering splashing out on hard-wired electrics.![]()
”under” is fine….”in” is more of a challenge, particularly if “unfeasibly large”!!!Your choice but some of us are masochists and like sticking unfeasibly large batteries under... steady @JOG ... our backside and solar panels on our roof.
Doing it this way can be as reliable, expensive or as neat as you decide to make it... some bits of mine are quite tidy and haven't caught fire yet.![]()
