Sliding door step removal
Camps
Hi all, my first of many posts from me no doubt! I have a 2019 shuttle with a damaged sliding door step. It looks like it has tags, top and bottom at either end as well as the usual clips on the base and back. Do I need to remove interior trim either side of the step in order to remove it?
Cheers Camps
Hey - My kombi one just pulled out with a bit of force (lift directly up not pull away out from the door)
All steps lift straight up but yes any adjoining pillar trims that overlap the end of the step will need to be removed
