Hi. I stand by the 'dead easy' note. It really was. The door is fully open when you prop it (not partially) and they are spline bits. Can't remember the size as when trying to find out on the internet there was conflicting opinions on what size. I bought a cheap small set. think it was M12?Hi Adam,
I'm encouraged by your "dead easy to fit", I'm hoping it's just a matter of supporting the partly-opened door, undoing two bolts highlighted and replacing the part. But what bit do I need for the bolts? I don't have anything that fits this.
Thanks, Roger
Hi, thanks very much for your detailed advice. I will buy a set of bits, I'll spend the extra money on high-quality bits as in my (admittedly limited) experience high quality bits fit the bolt heads better and have less chance of damaging them. While I'm waiting for the bits to arrive I'll clean the head and soak the bolt in WD40.Hi. I stand by the 'dead easy' note. It really was. The door is fully open when you prop it (not partially) and they are spline bits. Can't remember the size as when trying to find out on the internet there was conflicting opinions on what size. I bought a cheap small set. think it was M12?
If I recall there was one tricky bit - the bits can be REALLY tight so you have to be carefull that the bit is fully seated in the bolt head (clean it out with apin if necessary and WD40 the bolts) before 'cracking' it. Also, I think I had access issue to one of the bolts (one nearest the door I think) - the head of my rachet fouled the door before it could fully seat in the head so I had to put vice grips on the bit. I t was fine though.
Yours looks like it has the cable for electric door (mine does not) and the part I got has the piece you connect that to, which I just left there.
youtube vid on roller replacement
that is the video I followed. There's a few out there and this was the best one for me.
Good luck and let us know how you get on.
Thanks for the advice, I'll look at those.I have this set which is hex (allen), torx and spline bits. They sell a much cheaper spline only set. In an emergency, an allen key will fit a spline bolt (6 points Vs 12 points)
Clarke CHT144 40 piece Torx® Spline & Bit Holder Set - Machine Mart
www.machinemart.co.uk
Actually the two spline bolts are M8.Hi. I stand by the 'dead easy' note. It really was. The door is fully open when you prop it (not partially) and they are spline bits. Can't remember the size as when trying to find out on the internet there was conflicting opinions on what size. I bought a cheap small set. think it was M12?
Yeah i just ordered the one from just kampers as the roller has sheared off mine....looks like its been gone a while back in its day as a hire van as the guide is a right mess, may have to clean it up and coat it with something........I've just ordered this for VW TRANSPORTER T5 sliding door roller guide hinge bottom left 7H0843397 AA | eBay as mine isnt as smooth as the other side. Ill advise how it goes.
good price, assume not oem, as that is more, good spot£18.99 autodoc
Replace it. And spray the wheels liberally with a dry ptfe airosol sprayView attachment 199231 View attachment 199232
The sliding door is not quite as smooth as I’d imagined it should be. I’ve noticed that the lower hinge wheel is only intermittently spinning when I slide the door. And it’s rubbed the paint off.
The hinge itself is pretty rusty.
I’d like some advice if anyone else would just replace the lot or should I try adjusting the door as maybe it’s dropped and not lined up properly?
@minmax89 Thank you! Appreciate the replyReplace it. And spray the wheels liberally with a dry ptfe airosol spray
