I'm having issues with my sliding door rubbing and was hoping you kind people could help clear up a few things. Had a look through the forum for related threads but other people's hinges seem to be rubbing in a different area than mine.
The middle roller on my sliding door rubs off the cover panel circled in the picture. I see there is a spring on the roller but I'm not sure how this should work. When I push the door towards the van it stops the rubbing as there is play in it but once the pressure is removed the door comes back out away from the van. Is there play in other people's doors ie. Towards and away from the van or should this spring/roller keep the door pulled in tight to the van. Thanks!
