I wanted a simple, single bed in the back of my LWB Kombi with storage space underneath. I wanted to be able to remove the bed quickly when I need the cargo space.
Here's what I did ...
Materials:
4 x 3,000mm plus 1 x 2,000mm black steel square (25mm x 25mm) tube and 8 x 3-way and 4 x 4-way 25mm tube connectors (plastic outer with steel core) from Richardsons, 6 Collingwood Court, Riverside Park, Middlesbrough, TS2 1RP, 01642 242 228.
1 x Milliard 15cm Thick Tri Folding Mattress/Trifold Guest Mattress - Single (190cm X 90cm) from Amazon.
1 x 2,440mm x 1,220mm x 18mm hardwood ply cut to size from B&Q.
Miscellaneous timber lying about the garage.
Build:
1. Cut the steel tube to size (6 columns 462mm, 6 cross beams 610mm, 8 cross beams 810mm). NB. The sizes were chosen to make a frame that will take and secure standard Eurocrates (600mm x 800mm base) with a frame height to match the rear seat height when the back is folded flat.
2. Assemble the steel tube with the tube connectors to form the frame.
3. Cut the plywood to size and fix batons to stop the ply slipping off frame.
4. Put the mattress on top of the frame.
5. Have a good night's sleep!
The steel tubes and connectors ....
Cutting the tube ...
Tube all cut - 8 x 810mm, 6 x 610mm, 6 x 462mm ...
Layout the base connectors, top is the same ...
Connect the tube for the base, top is the same ...
Place base in van and fit columns ...
Put the top on the columns to complete the frame and secure it to the RHS lashing points ...
Cut the timber - 4 x 610mm lengths ...
Screw the timber to the underside of the plywood to stop it slipping off the frame. Note the fixing is asymmetrical. The ply is 900mm wide to match the mattress ...
The mattress in it's stored position ...
The mattress when folded out. If the rear seat back is up this gives a bed length of 1,850mm, hence the squashed mattress. If the rear seat back is folded down the mattress can be better placed and used to it's full length of 1,900mm ...
Materials:
Build:
