(Side Assist) / (Blind Spot Detection & Rear Cross Traffic Alert) retrofit
C was never made for PQ - only for MQB
so you must downgrate them to B + proper data set
Spacewalker is right, and probably this could be one issue.
Looking into ETKA for the Sharan and Seat Alhambra till 15.07.2019 5Q0907686B was used.
After that time VW switched to 2Q0907686B.
So there must be a reason why they did not jump to "C".
Even if you can Flash "C" and Code the "C" to PQ35, probably it will not work because of some incompatibility which was introduced with "C"
I will try my setup with "B" when i find time ...
So this incompatibility of C version must be exclusive to automatic braking element of RTA only.
Cause everything else works 100% on PQ25 as I have already verified.
Just found this :whistle:.
and this one
I am getting fed up :( . Waiting, waiting, waiting and still nothing arrives :cry:.
I have changed my mind and I will re-pin instead of using adapter loom.
Both plugs are already purchased and I hope to get them quickly.
I have upgraded my PDC Modul to 1K8 919 472 C
But now I get the error: U1121 00 [009] - Missing Message :eek:
  • Wow
Reactions: mmi
Ouch :oops:. Mine is still on it's way. Any more details - missing message from where? Interested to see the section of the scan.
