Has anyone any advice/instructions on the above. I’ve removed the bottom anchor point for the seat belt and this releases the bottom bit. However, I am struggling with two fixings higher up that I can’t get enough room to undo (see photos). Any help gladly appreciated.
They just need to be yanked out, if you have any plastic trim removal tools you can use the curved crowbar type one to get in close to the head of the popper and pry them off hopefully without breaking them but often you will need one or two replacements as they can snap
If you can free the fixed popper which i think is the top one then you could try sliding the panel downwards and this can release the head of the poppers from the slot they sit in as the slot is open topped as you can see in the picture
Thanks for giving me the faith that it would be ok @Pauly! Managed to squeeze a screwdriver in and pop them off. Just got to find the right torx bit now.
Haha! Thanks again. Still learning...
I know just enough to know mashing heads is not good, but not enough to know the difference between torx and spline.
I was going to find out like a toddler with their shapes game!
